Steve_Karl
Does anyone have a URL to where to buy nickel shielding paint?
Thank you!
Thank you!
Steve_Karl said:I'd never heard that the copper tape gave better results.
line6man said:Steve_Karl said:I'd never heard that the copper tape gave better results.
It does.
I've seen readings of 4 ohms on the second coat from neck to bridge cavity with paint, versus 0.5 ohms with copper tape.
line6man said:This stuff occasionally pops up on eBay:
http://cgi.ebay.com/Guitar-Conductive-Shielding-Paint-Acheson-Electrodag_W0QQitemZ230376023084QQcmdZViewItemQQptZGuitar_Accessories?hash=item35a37b242c&_trksid=p4999.c0.m14
line6man said:It does.
Super Turbo Deluxe Custom said:line6man said:It does.
Does the ohm value really matter in this case. It is not a grounding path as far as the circuitry is concerned. The purpose is for it to be a conductive path to ground for any unwanted interference.
jlegnor said:Are you guys taking readings with the guitar plugged into an amp? Cause unless the guitar is connected to some kind of outside ground, wouldn't the shielding in the guitar be just a floating ground?
Cen-Tech has a real inexpensive multi meter that's easy to use, I bought to use for checking the bias on my amp.Easy to use and works great, I think it was like $10..Steve_Karl said:This is really interesting to me.
Can anyone recommend a good entry level multimeter form someone that's never owned one?
Thanks!
