The plan here is for a white blonde finish, BB#1 in the neck, hottish tele pickup at the bridge, which will be slotted, and a Bixby B5 installed. The neck.. just a hint of tint. Gonna see if I can scrape up some Fender F tuners, maybe an F neckplate too. Try and make it like my old, long gone, 72 tele. Maybe even a bit of relic added, dunno yet. I do know that my old 72 was pretty opaque on the edges, and more transparent on the front and back, and I'm hoping the black grain fill will help that sort of "see the grain" through the finish look. This body weighs 4lbs 2oz... pretty light!
Grain filler is StewMac black, waterbased. Ya cant hardly scrape too much off with the bogus credit card (sample) I'm using. Thats to keep the sanding to reasonable levels. Filler is hard to sand off. I like the 3m sandnig block (rubber) for the flat spots. Keeps a very flat finish that way. As I cannot spray a thing here with this weather, I'll let this filler sit a week, then sand it back and give it coat #2. This body is not as coarse as the thinline I just did, so maybe we can get by with 3 coats of filler. Takes about 15m to go over the body and cover it with filler.
