Wana's_makin'_a_guitar said:Cool Beans
Sure about the bridge drilling though? :icon_scratch:
RockStarNick said:I'm pretty sure that Home Depot or any hardware store sells Poplar Dowels in 1/8" diameter. Close enough to alder, and that trem is going to cover it anyway.
Its sound like you have done this all ready. Do you have a hipshot?=CB= said:Dowel it, and redrill it. The hipshot will probably cover it.... unless you cut little disks from a cavity and insert them into the top 1/16th inch or so of the patch. I wouldn't bother, since it wont be easily seen.
ZGOZZ said:Its sound like you have done this all ready. Do you have a hipshot?=CB= said:Dowel it, and redrill it. The hipshot will probably cover it.... unless you cut little disks from a cavity and insert them into the top 1/16th inch or so of the patch. I wouldn't bother, since it wont be easily seen.
OzziePete said:ZGOZZ said:Its sound like you have done this all ready. Do you have a hipshot?=CB= said:Dowel it, and redrill it. The hipshot will probably cover it.... unless you cut little disks from a cavity and insert them into the top 1/16th inch or so of the patch. I wouldn't bother, since it wont be easily seen.
Changing from one type of trem unit to another can sometimes result in having to redrill somewhere or plugging some left over hole. Doesn't have to be a Hipshot to have this thing happen.
Also happens with stud holes for Tune o matic bridges and tailpieces for LP bodies - there's a 1001 variations of that type of bridge and tailpiece and you have to be careful in getting the stud holes matching or end up doing this task on the LP body.
I will get some pic's latter today..
Got a photo of the Hipshot?
Yea I filled them.DangerousR6 said:so it appears the you got them filled? :icon_scratch:
Cool, what did you get to fill them with? :dontknow:ZGOZZ said:Yea I filled them.DangerousR6 said:so it appears the you got them filled? :icon_scratch:
:icon_thumright:ZGOZZ said:RockStarNick said:I'm pretty sure that Home Depot or any hardware store sells Poplar Dowels in 1/8" diameter. Close enough to alder, and that trem is going to cover it anyway.
What RSN said that's what I did....
RockStarNick said:Nice! looks great man. That's just about as good as it gets. What kind of finish are you going to do?
