bluewaterjon
Hi, I have been using a Warmoth all palisander roserwood strat neck on a Warmoth body. I am getting a new neck, and I want it to match the specs of the neck that came with my stock maple neck from made in Japan HSS Fender strat that I bought in around 1990, serial # L035465. This stock strat has a Floyd Rose and I guess it may have been set up for shredeers but I loved it. I called up Warmoth, but they have no record of the purchase because it was pre-2007 and thus can't figure out exactly what I bought. I do know the neck width is 1 5/8 and the neck of the maple stock strat neck is 1 11/16 so that's a big help, but I am stuck on several other important specs, the major one being the fret size.
I love the size of the frets on the fender (above). They seem to be fatter and a bit lower than the Warmoth ones ( or at least their tops have been filed down, if they do that at the factory, cuz I have never had either neck's frets dressed, crowed, etc) I sent a pic of the Warmoth fretboard to Warmoth and they guestimated the frets are 6150. So I figure. well maybe the frets of that stock strat of mine ( which have never been messed with in any way) are 6130's, which Warmoth says are found on many Gibsons. I like the ones on that maple strat neck because they don't feel so bumpy when I am running across them. But I am concerned that if I get Warmoth 6130's, they will be too low, like the "fretless wonders".
Before I go ahead and order the 6130's, I thought I 'd share the pics with you and get your input. I notice that the Warmoth frets seem to be almost like a perfect half circle, while the frets I like better, the ones on the stock maple strat, seem to be lower, or if maybe they were simply ( not sure what the tech word is here) filed down at the factory to be flatter on top. I'd hate to order the Warmoth 6130's on my new neck and then realize they are not the same frets as the ones on my fender.I'd send the fender neck to Warmoth but they said they don't do that.
Also I need help on the neck dimensions as far as the depth of the neck. On my Warmoth neck, the nut width is 1 5/8 and at the 12th fret it’s exactly 2”. The depth of the neck ( as measured from back to front) is almost 13/16 at fret one and exactly 13/16” at fret 12.
In contract the stock strat neck is1 and 11/16" and 2 1/16" or a hair more at fret 12, and of even greater difference is that, compared to the almost uniform depth of the Warmoth neck depth, the neck depth is 12/16 at fret 1 and 13.5 /16" at fret 12.
So, I am wondering, with the dimensions I have for my older strat neck, which back of the neck profile would I pick, and which frets would I pick? The best data I have on the frets comes from looking at the pics. Keep in mind the maple neck is the one I am trying to duplicate.
Thanks for any and all input!!!
Jon
Jon
