C Cederick Guest May 31, 2015 #1 If I decide to go wtih 720 mod and contoured heel I figure I can't use regular screws, and maybe not even the shorter screws?! The hell must be very thin, I suppose
frown Senior Member Messages 265 Jun 1, 2015 #2 Hi Cederick, You are correct - with the 720 mod, the standard contour heel screws are too long! I solved it by buying a couple of shorter length stainless steel screws from a machine shop, rather than trying to cut / grind down the Warmoth ones. The No.8 screww lengths I bought are 1-1/4" and 1-1/2" I'm pretty sure I used 3 shorter ones and a long one to do a best fit scenario, and everything seems solid enough - with no fingerboard breakthrough! Hope this helps.
