dmraco
Master Member
How deep should neck screw go into a neck?
I am dealing with a body that is only 1.5 inches thick. If I use the stock screws, there come to just under the fretboard. If this too long? I bought some slightly shorter screws but they go about 1/2 way into the neck. There is no other size available.
I would also grind a few mm off the longer screws.... :dontknow:
Thoughts?
Thoughts?
