I have a Swamp Ash/Quilted Maple top finished Strat Body and a maple/rosewood unfinished neck. I see people posting worried about the pocket being tight but my problem is the opposite. The neck takes very little pressure to seat all the way down and the weight of the neck is enough to tilt the neck in the pocket if I lay it down flat with no neck support.
Do I need to worry about this? Or clamp it down with the plate (after checking alignment of course) and the four screws and call it good? I'm kind of a perfectionist about stuff and this is my first build (i'm doing two builds in parallel) Should I just let a little neck finish get on the heel? I was thinking to build up the pocket a little bit with medium Cyanoacrylate? (I've worked with all viscosity of super glue including laminating with it so Im comfortable with it). My thinking is that sets up very hard and I can sand it to a very good interference fit for the neck and my thinking is its so hard when its set up that it should not be a tone robber. Sure given my option I'd take a good barewood to barewood fit. But the neck and body were both chosen for their looks (i'm doing this for someone else) so I have what I have.
Any and all advice welcome.
