neck does not fit pocket, which do I sand ?
1jimbo
My new Warmoth Strat neck is WAY too tight in my new Warmoth body. I dont want to beat it in. Which should I sand, neck or body ?
I wood* also hook up the outside "E" tuners and mock-fit the bridge, and either sacrifice a couple of strings or use a straight straightedge to check that everything lines up as you're sanding - it's going to be a LOT less frustrating to toast off a few strings early than to have a crooked neck.
*(Ha ha! Hahahaha! :-\)
