So I received two parcels from Warmoth a few weeks ago and have slowly been getting the hardware in while putting a few coats of Tru-oil on the body.
Body specs include a Soloist body with Mahogany core wood and a Koa laminate top. Contour neck heel, Floyd Rose with angled neck pocket routing. I asked Warmoth to only have index points marked for the tremolo studs as I'm going to use a Gotoh GE1996T Floyd Rose and the locking studs require a bigger hole than regular OFR/Schaller studs. Also had them leave out any holes for the controls as I wasn't quite happy with the placement of the regular options. Going to have a carpenter friend use a drill press to drill out the stud holes and a hole for a push-push pot to serve as volume/pickup selector once the finish is done. Also going to try to do the direct-mounted pickups with a brass inserts sunk into the pickup routes instead of just wood screws so a drill press is going to be handy there too.
Neck is quartersawn Pau Ferro core with a Pau Ferro fretboard, Modern Construction Warhead with reverse headstock, Stainless Steel 6150 frets, 59 Roundback profile, 1-11/16" nut width, 25.5" scale, Warmoth compound radius, Floyd Rose R3 nut prep. Used a regular fretboard deep conditioner oil for the whole neck once it arrived which made it look really good and rubbed in some Warwick Surface Finisher wax (which should just be regular beeswax). Damn does it feel smooth and quick!
Anyway, here's the progress so far: Link to OneDrive album
