Wana_make_a_guitar
I love the Boosh. :icon_biggrin:
Super Turbo Deluxe Custom said:Hannaugh, since Smavridis changed his avatar to his picture, he's hard to be offended by or taken as "snippy."
AprioriMark said:It always amazes me how some people will disagree about ANYTHING just to feed their own ego. Especially when their own experience is so limited and the subject matter is creative in nature. Just ugh.
-Mark
jerryjg said:AprioriMark said:It always amazes me how some people will disagree about ANYTHING just to feed their own ego. Especially when their own experience is so limited and the subject matter is creative in nature. Just ugh.
-Mark
I disagree.
=CB= said:Ok, just some food for thought....
Why does the wood need to breath? (Response) In my experience older guitars sound better from aging. But only those that don't have a lacquer. (Opinion) Why? Because you restrict the guitar from expanding and contracting like it normally would. If you allow it to breathe it increases resonance "Some"! Keyword "Some" It does not destroy the tone of the wood completely. Many master violin builders in Europe have took that into consideration for years. They use only maple that they've aged in uncontrolled temperature enviroments for 40 years.
They also use formulated shellac, though on the outside of the guitar to improve tone. Which works for that instrument. As a generality though expensive violins are always form aged woods.
Why does poly hurt tone. What property of a poly finish is different from other finishes that makes that so? Under what conditions does poly hurt tone?(Response) It doesn't hurt it necessarily. It does change it though. And I hold firmly to that. It just depends upon what you like to hear.
Could poly improve tone? If so, under what conditions? (Response) Honestly, I'm not totally sure what it could improve. You'll agree everything is subjective and up to personal preference.
We cant take the same exact body and pickups and neck and refinish it - so we have to draw on generality, based on large samples of poly vs whatever. What other specific traits did those large samples have? Was there anything specific to those poly finished guitars that varied, or was different from the other guitars?
Let me give you a "for instance"....
A person might like the sound (tone) of a twin pickup ES-137, and not like the tone of a Telecaster. So one might conclude the following:
Solid bodies suck for tone.
Poly finish sucks for tone
Single coils suck for tone
Maple fingerboards suck for tone
Maple necks suck for tone
Bolt on necks suck for tone
Angled pegheads improve tone
....and the list goes on and on.
But, we know there are GREAT and FANTASTIC and KILLER sounding guitars with solid bodies, poly finishes, single coil pickups, bolt on maple necks with maple fretboards, and straight headstocks. And there are terrible guitars with hollow bodies, nitro finishes, HB's, and glued in mahogany /rosewood angle peghead necks.
So that leaves a huge giant HMMMMMMMmmmmmm in ones mind.
To all that, I've concluded its hogwash.
Real tone comes from the knob that is labeled "Tone" (or is blank but has the same function).
With the selection of the right knob, all will be right with the world. And knobs are easier and cheaper to change than pickups, or necks or finishes. So if the strat knob doesn't cut it, use a bell knob, or speed knob, or wooden speed knob....
But, when you change knobs, please be sure to use knobs made of old wood, or vintage plastic, or better yet "phenolic" plastic. Make sure your brass knob is made of bell brass, not common brass. And the set screw... it must NEVER be a socket head type, or a philips head type, but ALWAYS a single, shallow slot. Yah they tend to let the screwdriver slip, but that is where the real tone is made.
Then go out and learn to play your guitar.
Well I haven't heard it so I couldn't say. I am a strong believer in high end components though. I figured you weren't talking about pots. Sorry about that! :rock-on:=CB= said:Sarcastic? Just look at this link.... fully supports that knobs make a difference
http://www.boingboing.net/2005/11/07/astronomically_overp.html
AprioriMark said:stubhead said:If you've ever played an old guitar that was played lovingly by intent musicians, and then played the same model that was kept in a closet for 50 years,
This happened to you? Which guitars?
Specifically, holly bodies (Gibson Super 400 and a 40s Epi Archtop... I think a Zenith) played by Dixeland/swing musicians. When I was a youngin', I had the experience of hanging out with an amazing player at a festival who was a friend of my grandfather's, and he was looking to replace those two guitars. We hit up auctions and estate sales, and he'd already bought a couple Super 400s. He had all the guitars he bought set up by the guy who'd been setting up his current axes, and without fail, the ones that had been played ended up sounding and "feeling" better than the closet guitars.
While this is certainly not a cross section of all guitars or any sort of empirical evidence, it's in keeping with the old orchestral idea that great instruments take on some of the life of their owners, and that the wood carries on the "soul" of the people who've played them.
-Mark
=CB= said:Folks, having been there/done that with putting different necks on the same body.... necks made of differente woods, or the same wood with different fretboard material, I can tell ya....
Ruling out the player.... and the amp (because the amp is half of the tone at least, and an instrument in itself)
#1 - its the pickups stupid
#2 - neck wood and contour. I dont thing maple vs ebony vs rosewood vs goncalo vs pau ferro makes a difference on an otherwise very stiff neck - like maple. On a mahogany neck or other neck with some wood less dense than maple, less stiff than maple, then there is probably some effect.
#3 - how you wire it
#4 - strings
#5 - everything else in a very distant last place. Finish - nil effect on a solid body. Bridge, almost nil, nut almost nil, fret material, just over almost nil. Certainly there is more effect in tone with changing string type (ie pure nickle vs plated, vs stainless) than in fret material.
Jeremiah said:This is a bit of an old thread, but not quite dead, I hope...
I'd be interested to know what effect you think the neck/truss rod construction has, eg Warmoth Pro vs vintage style truss rod.
Superlizard said:Basic tone rule of thumb: less is more.
