spauldingrules
Okay, just pulled the trigger on my Mustang (fender body, warmoth neck). I want to use one of the switched to select neck/both/bridge pickup and the other for something else like series/parallel or something. I am mostly concerned with using 1 switch to select the pickups, though. There are 8 lugs on the back of the switches (see here: http://www.warmoth.com/hardware/parts/parts.cfm?fuseaction=include_switches). Can I connect the middle ones and treat it like a 6-lug switch? Or do I need to do something different? I really don't have use for the phase setting on the original Mustang wiring.
I will be using noiseless single coils (dimarzio virtual vintage) so I don't really need to "split" the pickups, but it would be nice to use the extra switch to put them in series/parallel with one another - is this even possible?
Thanks, and schematics are GREATLY appreciated.
- spaulding
- spaulding
