Cagey
Mythical Status
bagman67 said:I have no direct experience with the following, but I recall reading a tip somewhere about soldering to the back of pots: If you scuff the surface of the pot slightly with a file, it helps form a better joint. Can anyone weigh in knowledgably about the accuracy of the foregoing?
One of the secrets to a good solder joint is good mechanical joint, so an abraded surface will have a better grip. But, usually more to the point, it cleans the surface of any manufacturing oils or finishes that solder doesn't want to join with.
When you get right down to it, soldering to the pot's housing is an old practice born of laziness and the OEM's desire to save a penny. What really should be done is the addition of a grounding lug washer.
That gives you a proper connection without ever needing to overheat the pot. You just install that on the pot's shaft as you mount the pot, then solder your grounds to that. It automatically grounds the pot's housing in the process. Tough to find the little rascals, though.
