beowolverine93
What is the difference between a mono and stereo jack?
beowolverine93 said:Which are? Thanks for the photos by the way.![]()
deajo said:whoa...one sec...i have a stereo jack in my strat (LR Bags piezo X Bridge) with preamp. Do I have to use a special cord with that output jack?
I have been using just normal cords with minimal success...it does allow me to blend the piezo and magnetic pickups, but i was under the impression
I could split the signal with a "Y" cord (if that makes any sense)...i wanted to send the magnetic signal to my tube amp and the piezo signal to my acoustic amp
...i bought a "Y" cord...it doesn't split the signal...i can't remember if it was a stereo "Y" cord or not (or if one is even available)
anyways, any help on this subject is greatly appreciated...i was never one for reading manuals :doh:
Cagey said:deajo said:whoa...one sec...i have a stereo jack in my strat (LR Bags piezo X Bridge) with preamp. Do I have to use a special cord with that output jack?
It depends how it's wired, but it's very common for the magnetic and piezo signals to be on separate lines so you can do just what you did. The "Y" cord you used may or may not have broken those lines out to separate channels. You can get them either way.
Cagey said:[/center]![]()
TRS jacks are also used for balanced signals in pro audio gear. Manufacturers started using TRS jacks to save space on their gear (instead of using XLR's). The tip carries the "hot" signal, the ring carries the "cold" signal (inverse phase), and the sleeve is the ground. They are also used as insert jacks, where the tip is the send, and the ring is the return. The other end of the cable would have 2 seperate connectors (input and output).Cagey said:beowolverine93 said:Which are? Thanks for the photos by the way.![]()
Well, I believe they were originally designed for telephony switchboards, so it's a very robust design that'll take a lot of abuse. The TS jack is most often used to connect single-channel signal ports, while the TRS does dual-channel. So, in the case of audio, that usually translates into mono or stereo signals.
You don't have to use them that way, though. Any signal you want can go on those conductors. It's just a good idea to use similar signals so you don't trash one line by contacting the other while plugging/unplugging the connector.
AndyG said:TRS jacks are also used for balanced signals in pro audio gear. Manufacturers started using TRS jacks to save space on their gear (instead of using XLR's). The tip carries the "hot" signal, the ring carries the "cold" signal (inverse phase), and the sleeve is the ground. They are also used as insert jacks, where the tip is the send, and the ring is the return. The other end of the cable would have 2 seperate connectors (input and output).Cagey said:beowolverine93 said:Which are? Thanks for the photos by the way.![]()
line6man said:AndyG said:TRS jacks are also used for balanced signals in pro audio gear. Manufacturers started using TRS jacks to save space on their gear (instead of using XLR's). The tip carries the "hot" signal, the ring carries the "cold" signal (inverse phase), and the sleeve is the ground. They are also used as insert jacks, where the tip is the send, and the ring is the return. The other end of the cable would have 2 seperate connectors (input and output).Cagey said:beowolverine93 said:Which are? Thanks for the photos by the way.![]()
Additionally, many of the people who are paranoid about batteries dying on their guitars opt for external DC power supplies to provide for the active components of onboard buffers, preamps and active pickups. (Of course, this is fricking ridiculous, but that's another topic.) Relative to the ground potential at the sleeve terminal, a positive direct current source is often run through the ring terminal. A notable example of this application is the Line6 Variax guitars, and their external power supplies. I believe that EMG has recently introduced a stompbox power supply unit, as well.
Rickgrxbass said:line6man said:AndyG said:TRS jacks are also used for balanced signals in pro audio gear. Manufacturers started using TRS jacks to save space on their gear (instead of using XLR's). The tip carries the "hot" signal, the ring carries the "cold" signal (inverse phase), and the sleeve is the ground. They are also used as insert jacks, where the tip is the send, and the ring is the return. The other end of the cable would have 2 seperate connectors (input and output).Cagey said:beowolverine93 said:Which are? Thanks for the photos by the way.![]()
And I haven't been able to find it again, but I vaguely remember an article in Bass Player years ago about rigging up an XLR jack onto a bass in order to use a phantom power source to drive a preamp :icon_scratch:
