I was wondering if it's possible to take an existing humbucking pickup and alter/modify only one of the two coils.
The reason I ask is because I have a dual humbucker guitar with a switch that gives me one coil from each in parallel in the center position. I really like the way it sounds with the current pickups. Conversely, I find the neck humbucker in standard series mode to be a bit too fat. I know that if I were to change this pickup out for a brighter humbucker, the center position would change and I don't want that to happen. This is generally the problem with series/parallel for me - the tonal change is always a little more extreme than I want it to be.
So I was thinking if the coil that is being used in the center position is left untouched, can I change the tonality of the humbucker by manipulating the other coil? Can some col wind be undone to lower the output and make it a little brighter? Mind you I don't really know anything about the construction of a pickup, and I'd have a tech/pro do whatever mod if I thought it was a good idea. I know some companies produce humbuckers with coils that are mismatched for different tonality, so i know it's not a structural impossibility.
so, yes.. thoughts?
so, yes.. thoughts?
