Super Turbo Deluxe Custom
Epic Member
Mixing probably needs the least amount of explaining, but mastering it seems is thrown around a lot.  I may not know what it means, or I hear it misused a lot.
As per usual the internet is full of different definitions. As I understand it, it goes beyond mixing and is done after all mixing and recording is done. It is done to equalize track to track volume, and sometimes requires some individual track tweaking. My analogy would be paint matching a vehicle's body components. Each piece (track) is painted (mixed). Each piece was painted separately on a different day, location, by a different painter with a different mix and a different gun. Each piece looks great on it's own and are technically all the same color, but upon assembly, all the pieces are a slightly different color. Per the analogy, you can't match paint after the fact, but if you could, it would be an example of mastering. Biasing tubes might also be an example of mastering. Different outputs, but biasing equalizes them to act uniformly.
Thoughts?
Thoughts?
