W
Watershed
So I gave the 'ol Mesa DC-2 (Studio Caliber) some new tubes over the weekend and thought I'd share some shots of the insides for those interested in amps.
This is a 1993 Mesa Boogie Studio Caliber that I bought new in 1994 or so.
The preamp tube locations are written right on the board. This is the V3 tube. To the right is the V2.
It has been a very reliable amp over the years, and if memory serves me, the preamp tubes are original.
Having spent a fair amount of time reading up on amp design and construction I'm looking at the internals in a whole different way.
I have a slightly better idea of what I'm looking at.
The Studio Caliber was one of the first Mesa's to have "Dyna Watt Power."
Looking this over, I see what appear to be 4 rather large filter caps, in addition to a choke.
If nothing else, the current is probably pretty well smoothed out after the rectifier.
I was a bit surprised to see the Sprague caps in there.
I was never really a fan of the lead channel. I always thought it had too much gain and sounded washed out.
I replaced the V2 tube (lead drive) with a 5751, to tone things down a bit.
The 5751 is a replacement for a 12AX7 with about 30% less gain.
I also thought I would try a "matched" 12AX7 tube from Torres Engineering in the phase inverter position.
The idea here is that a 12AX7 is a dual triode, and the "matched" tube is supposed to have a matched A and B side.
This would be useful in the phase inverter position, where one half of the 12AX7 is feeding one power tube, and the other half of the 12AX7 is feeding the other power tube.
No point in matched power tubes, if they aren't getting a matched signal to begin with.
I get the theory.
I also picked up a new set of Ruby Tubes EL84's, which are just rebranded JJ's.
Here's what I got:
I do have a bit of corrosion where the tube sockets attach to the board.
Aside from being ugly, I don't think it has really presented a problem.
So the result?
Well the 5751 definitely tamed down the lead channel. It sounds less washed out and compressed.
Still plenty of gain in my opinion, but now with more character.
It's hard to quantify the benefits of the "matched" 12AX7, but in conjunction with the new EL84's, everything sounds very nice.
"Blossoming" overtones and all sorts of other guitar tone adjectives.
It sounds very nice, hard to describe though.
Everything sounds very "full."
I guess I should swap out the other 4 preamp tubes as well now.
James
I get the theory.
Here's what I got:
So the result?
James
