Maple/poplar/Walnut tele
dmraco
Master Member
I picked this up on eBay for $80.  IT was not without issues.  It had a crack in the back of the poplar and the neck pocket was far from perfect.
The crack has been filled with epoxy and I was able to fix the pocket by adding some additional material on the sides and reshaping.  It looks like the router/template must have slipped during routing.
There are also the telltale holes on the ambrosia maple.  I filled them the last time I used ambrosia, but I think I will leave them.
My plan is to cut a tummy cut and simply tru-oil the body.  I do not want a super glossy finish.  I had watched some videos since this will be my 1st time using tru-oil.  I was thinking of putting on a coat, let dry.  Second coat, let dry.  Hit with some 0000 steel wool then clean.  Add a final coat and buff with clean cotton cloth to rub it in.
Thoughts?  I would love to hear from the tru-oil experts.
Tummy cut done.  Easier to see from this angle.  I also did a very slight forearm.  I did not want to burn thru the lam top.  It adds just a bit more comfort.
Nice looking tele, I like the stripe..I did a similar guitar some time back, not a tele but with the wood stripes. And I'm no expert in tru oil, but I have used it several times. And pretty much the way you described, coat let dry, coat let dry...etc
And finished off with #0000 steel wool, and comes out not too shinny, but not too dull..
I remember that one Doug.  Good memories.
Do you recall how many coats you did?
It's been a while but I got this together.  The neck is amazing.  It's my 1st Wenge neck and I love it.  The blood wood with the black inlays looks great too.
The guitar turned out great.  I used a GFS single coil sized humbucker in the bridge and it is amazing.  Finish is just a satin poly.  Turned out great.  I did some slight relicing on the black hardware too.
The guitar is a bit heavy but not over the top.
Beautiful. What a fine look. The way the center stripe matches the fretboard is a bonus.
Thanks.  I will get some better pics.    I need to find a better image host server
DMRACO said:
Some better photos.  I need to get some smaller head screws for the neck plate.
20180707_142218 by dmraco, on Flickr
20180707_142238 by dmraco, on Flickr
Sweet, has a bit of flame in it... :icon_thumright:
The angle of the countersink of the screw maybe different. Or I just didn't countersink the holes enough. You could just use an 82* countersink on the holes to deepen them..
Those aren't oval head screws, and the head is slightly oversized. Looks like flathead countersunk #10 screws. #8 would fit better, but if they are #10s it's too late now - the neck screwholes are stretched too far. #8s won't bite.
You are correct these are flatheads but they are an #8.  I have used these on other neck plates with no issue.  This was made by Doug and is super thick.  The holes are not as counter sunk as others.
I since have removed the plate and counter sunk the hole a bit more.  It’s now flush.
That's good.
I've got a neck here now for a refret that's not only had #10s run into it, it feels like they've been run in and out a couple dozen times. There's almost no wood left in the holes until the very end of travel. Wouldn't be a problem if I drilled it out for inserts, but for some reason the customer doesn't want them. We're gonna have to have a serious conversation about this pretty soon.
