Mann Tremolo Compatibility with 6 Hole Vintage Trem Routing
vp101
Hi All,
I am wondering if the Mann Vintage 6 hole tremolo will fit into Warmoth's 6 hole Trem routing.
The reason I am asking is that Mann says the bridge will fit directly into a vintage 6 hole routing whereas the measurements on the two websites (Mann's and Warmoth's) are a bit different:
Warmoth Website: Mounting screw span is 2.2" (55.9mm)
John Mann's Website: Mounting hole spacing = 2.220" (56.38mm)
The difference is 0.02 inches or 0.48mm but I am quite concerned that about the mismatch in these dimensions as far as the mounting holes is concerned.
Would appreciate some help on this folks!
Thanks!
The Green Grinch
The Fender spec. is 2 7/32" or 2.1875", some rounding off is going on both at Warmoth and Mann. I don't think 0.020" will make any difference, so don't worry. I have a Mann 2 point on a VIP build, I think you'll like it.
Rick.
