mahogany options
S
swarfrat
My body is enroute. I'm waffling between various permutations of clear, red, brown, oil, poly, gloss and matte.
It's on the light side with a very light stripe down the center. Fortunately the stripe runs right through the bridge plate, so I can test both regions.
I'm thinking I'd like to really pop that stripe as much as I can. I don't expect it to absorb dye/stain at the same rate as the rest. I could be wrong. If I go this route, I'd like to leave the stripe as close to the color as it is while making the rest look "like mahogany" or darker with red/brown tint.
I'm also thinking that clear matte with no grain fill will probably look the closest to unfinished but wet as I can get.
Suggestions?
Initial thoughts.  I’d grain fill it with a clear filler. Then true oil it.
If you look closely, the pores in the striped area are about the same color as the pores elsewhere. I think if you lose that continuity, the strip may appear as something contrived rather than revealed.
Again that from a photo. Wait till you have it on hand.
On this build, I had hit it with black and red dye, and then sanded back the surface.  Compared to the back of the guitar, the front has much better popping of the grain.
Spamming the naptha pics from the OTB thread:
I think red could work but I'm leaning towards clear fill/matte at this point. And probably sticking with the tort guard.
