mahogany body with a walnut top, color suggestions?
jonn
:help: okay ive got bunch of 8ft long boards of mahogany to glue together for a body and some walnut tops that are sort of a pinkish, purplish color and was hoping to make a les paul out of them. i want the wood to be colored but still show the grain. i was wondering what color combination would best show off the grain. also what glues to use when i glue the mahogany and the walnut together. this my dad and my first guitar build and we really could use some help. :help:
Personally, I feel walnut looks best with an oil finish. It is also an easy finish to do, which is good for a first build.
Mahogany, you could do an oil finish, but you may want to fill the grain first.
I know you said you want a colored guitar, but clear is normally the way to go for walnut.
ill get pics of the wood soon but do u think it would look good if i just gave the mahogany a colored glossy finish but kept the walnut a natural glossy finish?
here's some pics of the wood and btw im not planning on using all the wood, just enough to make the  body and top
the top 1 is mahogany and the bottom is the walnut
i think an amberish tint would look good on those woods also.
maybe some high quality matte black spray paint? just kidding. dont do that. ever.  :toothy11:
try wetting them a bit. I can assure you that walnut will look way nicer, and an oil finish will be awesome. But something mild might not hurt. Maybe vintage cherry?
That's a very good suggestion. Rubbing a piece down with isopropyl alcohol is an excellent way to see what a wood will look like with a clear finish. It doesn't raise the grain like water does, but persists long enough before evaporating to let you stare at it for a bit to decide if you're happy. Plus, as a bonus, you get a bit of cleaning out of the deal, taking off handling oils, sanding dust and so forth. Some woods, like walnut and mahogany, produce startling results from that treatment.
I think all walnut shoud dye and turn green. Routing and sanding that stuff can make you sneeze yourself bloody.
that was my original idea! i was going to dye it green but i was told the green would turn out like a vomit color so after that i didn't know what color to use!
Ya I know. That's why I suggested green. I was kidding. What happened to your old account? The thing about walnut is it's a pretty dark wood and there won't be alot of contrast in the grain once dyed and the dye will be very dark. If I was in your shoes I would get a different wood for the top. If you are stuck on a green top you can go the traditional route of maple. If you want something cool but still a little different you could do just mahagony or korina something along those lines. It would still come out darker than a maple top and you could save that walnut for the reason it was intended (oil finished soloist with walnut neck ebony fretboard abalone inlays black chrome floyd and Dave Mustaine Livewires!!!!).
I would say if you want a colored finish, don't do walnut for the top (do maple, like pablo suggested).  And if you want walnut for the top, do a clear finish.
And then for whichever one you pick... make another guitar and do the opposite!  :toothy12:
Walnut darkens dramatically when you put a finish on it, so any transparent colored finish would be lost or so substantially altered that it's unlikely you'd be happy. Fortunately, clear finished walnut is gorgeous. If you want to see what it would look like with a clear finish, get some rubbing alcohol and a rag and wipe the thing down with that.
Lately, I've been convinced that zebrawood is great for the more interesting finishes. Perhaps a green-dyed (or tinted?) zebrawood top would be cool.
image.axd
like this trans turquoise?
