I have a neck on order that is being prepped for a Floyd Rose locking nut. This guitar is going to be converted to use the Buzz Feiten tuning system, which involves shaving off a small amount of the fretboard at the edge of the nut slot. To save the installer from having to fill/re-drill the mounting holes, I had the nut shelf done without the holes being drilled. I noticed that Warmoth drills through the back of the neck to mount the locking nut. My question is, is there any reason why I can't get two of the shorter screws and drill the holes into the top of the nut shelf, like all of the other Floyd guitars I've used in the past? I know that they can generally be mounted either way, but is there some structural reason why a Warmoth neck would require the screws to go completely through the back of the neck? Thanks.
