O
OzziePete
Hi Folks
I have stumbled across this handy mod for the standard Jazzmaster set up.. It uses the roller pots as individual tone pots and allows you to switch whichever pot you want to use to whatever pickup is selected on the toggle switch. Because the upper bout roller pots have different values (1M & 50K) they have a different affect upon the cap and resultant tone. The two lower bout pots become individual volume pots for each pickup - or you can swap them out for std. 250K or 500K pots.. This is more helpful han the standard wiring set up for the JM, which has the upper bout pots used exclusively for the neck pickup (V-T) and bypasses the lower bout controls.
If anyone has some other JM mods to share maybe post them here?
