Jazzmaster/Modified Mustang bridge
Tralfaz
I'm doin a JM build now with a Warmoth compound radius neck.I had planned to use a standard JM bridge but then saw the modified Mustang bridge.My question is ...is the only difference between a standard Mustang bridge and the modified one the ability to raise the outer most saddles?I have no issues using a standard JM bridge,but is it ill advised to use it with a Warmoth compound radius neck?
Use either the modified Mustang bridge, or a JM bridge fitted with Graphtech saddles.
(I would be tempted to use a tune-o-matic with Graphtech saddles - more solid conection)
If you use the standard JM, bridge, then you won't be able to set it up...
(action too high outer strings, too low inner strings)
But with the ability to raise and lower the saddles(JM bridge) wouldn't you be able to set it up? Is the bridge it's self,not the saddles,different on the modified Mustang bridge.
