TK4261
I just received my pre-wired Aquilar OBP-2 Bass preamp for my Warmoth Jazz build and I'll be matching it up with a set of Nordstrand NJ4's. I've wired up passive electronics before with regular CTS pots but never with a pre-wired preamp, I'm curious on where to connect the ground wires from the pickups for this setup.
Controls: Volume(pull for passive), Blend knob & Stacked Bass/Treble...
I know the hot/positive connection from the pickups get soldered onto the blend pot.
My question is, Does the ground from the pickups and bridge ground get soldered to the ground wire coming off the input jack?
Doesn't show on the Aguilar wiring diagram for where to connect pickup ground or bridge ground.
Any help would be much appreciated ccasion14:
