rstiltskin
Hi all. I'm back to update my situation. The Stewmac shims are made at an angle to raise the end of the neck (i.e. the last fret) and they don't make shims that do the opposite. And they are shaped so you can't turn them around. I tried a 1mm shim at the front of the neck pocket and clamped the neck gently in place and that wasn't enough to get the strings off the frets with the saddles at a normal height. I'm using a Hipshot hardtail bridge and luckily they sell shims that fit this bridge. After measuring, I've determined the bridge needs to come up 3/16" so the bridge saddles will be in a normal position. The shims are on the way. I will post pictures once everything is in order.
