EddieDavis
I've got a Fender Roc Pro 1000 combo amp - clean channel is solid state, and drive channel uses a single tube.
It's been crackling and popping intermittently while playing. Can't trust the amp to not do that at a gig so I've gotta fix it, until I can save up for a serious upgrade!
I've tried replacing the tube and it seemed to not crackle for a while, but then it let out a real nasty pop. Even though I was playing at super low volume, the pop was a single loud and sharp sound.
It has foil shielding inside so I'm thinking of replacing that with metal grill material, which I've heard is one thing that can help.
Is this something I can address myself? Or should I take it to a shop? I don't wanna put too much money into this amp anymore, as I've already paid a lot to have it repaired in the past. (last time I took it to a tech a few summers ago it was almost a $100 dollar repair on an amp that cost me $175 used) so I've already spent $275 into an amp that I will be upgrading from in 6 months anyways.
Ideas? Anything else I should check or try that I can do myself?
