Well i installed the tuners today how i found out how to install them, and well thought all was fine, but apparantly one of the screws didtn get enough grip in the hole, and now that tuner is a bit wobbly and i cant fasten the front of it anymore than i have done, is this rectafiable? however the problem is i cant remove the screw because even though i was using the right screw driver and i had the hole pre drilled, the head of the screw has bore itself out as i was screwing it in what i thought was tight, so now i cant remove the screw, can i solve this myself and get replacement screw, as a second is a bit like this, or would i need to take this to a luthier? if so i might aswell let him do all of it even the bits i can do cause im fed up of minor things making this project impossible.
