Hi, well decided today to have a look if i had the right drill bits for the few holes that need to be drilled, cause there not too major in terms of positioning and measuring as warmoth did the important ones, well i couldnt find small enough drill bits here, so im going to have to go get some, probably buy my first electric drill for university in september anyways.
but what i want to ask is should i attach the top horn strap holder on the top of it, or would it benefit being just behind the horn for stability and other such issues, its a five string z design bass with the warmoth headstock on the neck, swamp maple body, bloodwood fingerboard and wenge neck, case any of them are big factors in where i should place it. So any suggestions?
also for drilling,should i fasten the bass with some form of clamp that has a cushion of sorts between the body and the clamp, and drill the body using some tape over the area so the paint doesnt crack or would it not crack?
im just a bit pissed that here theres only two people that seem to do work like this, and well one ive emailed and not recieved a reply, and the other is at the city an hour from me, so if these holes can be done with the right preparation and tools then ill concentrate doing them myself, there the strap holders, 4 holes for the jack plate on the side of the bass, and another fourth hole on the front of the body for attaching a 3 way switch through it, as the volume and tone holes are too big, or else i would have got a fourth one drilled anyways. so would you say these are easy to do with right tools?
