Thanks in advance for any assistance here.
I'm fairly new to the electronics side of things.
I purchased and installed a brand new set of Fender Vintage Noiseless pickups in a strat today.
http://www.amazon.com/Fender-Vintage-Noiseless-Stratocaster-Pickups/dp/B0002E3D44/
Everything works well, except for one glaring issue, that I just can't seem to solve. There is a significant hum. It is almost completely eliminated if I touch my hand to any ground (bridge, jack plate, switch body, etc...).
The tone knobs don't seem to have any affect on the hum at all. The volume changes the volume and the pitch (frequency?) of the hum, but it doesn't ever go away completely unless I touch a ground.
One thing that I should point out. The kit came with three pots, two capacitors, and a resistor, and NO instructions!. One of the pots was 1 Meg, and two were 500k. The capacitors were standard fare 22k and 680k (pF?). I wasn't sure what to do with the resistor or the 680k capacitor, so I just used the 22k on the neck tone pot as per the drawing.
Since there were no instructions, I thought I'd play it safe and use a standard 5 way , 1 volume, 2 tone setup like this.
http://www.guitarelectronics.com/product/WDUSSS5L1201/Strat-Style-Guitar-Wiring-Diagram.html
I've double and triple checked everything. I'm fairly certain my wiring is correct, and I have gone over all of the grounds with my ohm meter and everything is grounded.
After getting the hum, and not being able to eliminate it, I started searching around the web and found an annotated review showing the resistor and 680k capacitor across two lugs on the volume pot "as per the instructions" (according to the amazon reviewer). So I added these to my config and saw no change.
I triple checked the output jack lugs to make sure they weren't reversed, so at this point I'm stumped.
I have a very rudimentary understanding of how this stuff works. I suspect there may be a short somewhere, either in the switch, or possibly with the 1 Meg volume pot (its just an uneducated hunch).
I have spare switches around, and some 250k pots. I'd really like to see how these sound with the included 1meg pot, so I think I might try replacing the switch first.
It's late tonight, so I'm going to sleep, and will get back on this tomorrow.
If anyone has any suggestions, or can shed some light on this, I'd appreciate it.
Thanks,
Jim
Edit: I attached the picture from the Amazon review showing how the resistor and smaller capacitor are installed. This is not my actual stuff...
Thanks,
Jim
