So I had my Warmoth guitar setup a while back but felt the need to tweak it. Anyways, I've ended up in a situation where the truss rod is fully loosened, or the nut you adjust it is.
Anyways, how many turns in should I start with with a fully loosened truss rod? When the truss rod was tightened down some I swear there was very little bow when the truss rod was almost all the way loose.
This is a Warmoth neck (like found here: http://www.warmoth.com/Guitar/Necks/Warmoth/Warmoth/ChooseConstruction.aspx)
Appreciate any help.
