Hi guys,
I'm in need of a new set of pickups. there are several things I always encounter, which I want to be solved.
I want a bunch of output. JB-style is just enough, I prefer more.
Mid and, midhighs and highs are my prefered eq-preset. I want and need a tight bass, lots of mids and highs. the JB has, for that matters, too much highs, well, its too icepicky, too piercing. it doesn't growl enough, so to say.
I also want it to have a huge, broad sound. the Prails have that character, but are too 'warm' too bassy.
I absolutely need supertightness and a very pure, direct, 'clean' string separation.
What kind, what brand of pickups would you recommend? I play a les paul, and my styles are very diverse. Jazz, blues, funk, rock, metal...
also, I want it to have many different, usefull sounds. coiltap, parallel, series.. all should be usefull, and completely different from the other. preferable with 2 very different coils, so that I have 2 coils which are very different in tone. prail-ish style...
any ideas?
I'll list what I've tried, and what I didn't like about it.
dimarzio bluesbucker (not enough output, not tight enough, not enough grit, not versatile enough, splitted or parallel)
dimarzio air norton: EQ-wise, they're ok. but not enough output. tight enough though. not broad enough (very flat sounding, no depth)
rio grande tx/bbq set: too vintage. broad enough sounding, but not tight enough. string separation for heavy metal? just isn't there!!
Seymour duncan JB: too piercing. tightness is ok. not enough output.
seymour duncan distortion: tightness is ok. but not diverse enough with the split/parallel sounds.
seymour duncan prails: versatile, tightness is ok, but it doesnt have as much highs as I would love to hear, and more 'clear' sounding (string separation) would be nice. more output: yes please!
motherbucker: great output, bit too warm, but ok, split/parallel etc is very good. tightness might be better though! string separation is ok. I really dig the rail design here; it eliminates the problem of volumedrop wilst bending.
burstbucker and iommi pickup by gibson: too nasal sounding. the BB's are too harsh, too nasal, like a wahwah pedal at half (the paf pro has the same problem!). the iommi has too much bass.
dimarzio x2n: too mushy. plain and simple.
dimarzio superD: too mushy, too much lows and lowermids.
dimarzio super2: nice with regards to the EQ, tightness is ok. but too flat sounding, not the depth, complexity I like.
bareknuckle nailbomb: not hot enough, pinches aren't as I want them to be (just wouldn't deliver the goods), too flabby with high gain and palmmutes.
bareknuckle mule: nice EQ, broad sounding is ok. but coiltap/parallel is just rubbish, output it too low.
dimarzio d activator neck (in bridge position): string separation: ok. but not broad enough, not complex enough. coiltap/parallel not diverse enough. tightness is ok.
EMG's: just suck in every aspect.
duncan custom: good EQ, not hot enough, its tight enough though. string separation is cool, but I notice somtimes a small drop in volume with bending.
I think I've covered all the pickups I've had or have right now.
any ideas?
