I think this is the soldering gun I'm going to get
Disco Scottie
It's so cute! Original article is here.
I think he stuck the wrong end of that soldering iron into the wrong end of that pony. Wait... did I say that out loud? <grin>
LesterGilmore9 said:
Can anyone give me some better advice what is soldering gun exactly..
First the device pictured is actually a soldering iron, a soldering gun does the same thing, but has a pistol grip and a trigger and heats up only when you pull the trigger.
But a soldering iron is a heating tool used to melt metallic solder to make electrical connections. You'll need one to wire up your pickups pots and switches if you build a guitar (unless you went with a prewired pickguard or a modular clip system like EMG and a few other manufacturers use)
