frustrated_jazzman
Hi everyone, I'm thinking of starting on my 2nd warmoth guitar project, and this time it's gonna be a stratocaster type (first project was all mahogany HH tele, neck and body finish by warmoth). To minimize cost, I'm thinking of doing the body finish myself using tru oil. I've read a few posts/seen a few videos about the process and it seems quite simple even for the inexperienced. I understand that too much humidity can be an issue when finishing a guitar body. I plan to do this in my home studio where I have a dehumidifier which I can run 24/7 at least during the finishing/drying. With the dehumidifier, I can maintain relative humidity levels to around 55 (humidity here can go up to 85 on rainy days, average is 75, on good days 63).
a few questions:
1. Is 55 relative humidity dry enough to do a tru oil finish? Would it be better to turn the aircondition on (together with the dehumidifier) to achieve lower humidity levels (around 40) during the process? As I can not run aircon 24/7 condensation might be an issue?
2. I do not really wish for a glossy, shiny finish. All I'm after is enough protection for the wood so it does not suck up any moisture from the high humidity ( and all the sweat it can get from playing), so how many coats is enough for moisture protection?
3. I plan to do this on an alder body (my neck is most probably a one pc maple satin nitro finish). What is the best/easiest wood to use for tru oil?
4. I'm getting a wilkinson tremolo rout for this project. Is it okay to have the studs pre-installed before doing the tru oil finish?
Thanks in advance for the advice.
a few questions:
