Hi everyone :headbang:
I'm planning to build my second guitar, this time it's going to be a thinline tele.
I would like to have a HS pickup configuration, where Humbucker is in the neck position and the Single coil is in the classic tele bridge plate.
So i've searched the web and i've come up with fender's wiring diagrams for sn HS tele here http://support.fender.com/service_diagrams/telecaster/011-8600A_SISD.pdf which seems easy enough to execute, but then i thought that i could try to add in the circuit a coil tap with a push/pull knob to split the bucker in the neck, and things got complicated.
Can anybody please help me out on this one?
Here's what bugs me:
1 When wiring a H+S, does the circuit go hum-cancelling on automatic on middle position with both pups on, or do i have to do something in order to achieve that?
2 What pots/caps are better suited for a H+S combination? 500ks or 250ks? 0.022s mf or 0.047s?
3 How do i add the coil tap in the circuit? Could anyone make me a diagram?
4 Would the coil tap cause a huge drop in volume? I would like to use vintage output pickups, so the humbucker will be either Grestch style Filtertron, a Fender Widerange or a 59' PAF.
5 Is it possible to have both a coil tap and a RWRP (if necessary) in the same circuit? How would the middle position sound?
