Prometheus
Hi all
I have on order a new body, and am trying to get organized while I wait for it. I have a question regarding finishing around some milling that I have planned.
The body back and sides will be black. I will be using threaded inserts for the neck. I'll be drilling out recesses in the body back for the ferrules. I would like to be able to not leave those holes with the bare wood showing (I know, hardly any, but still there). Rather, I'd like to paint them black inside and clear coat them. Also, I am not fond of the typical football-style edge-located jack plates. They sit on top of the body, and look kind of industrial, quite inelegant, and kinda clunky. I'd like to route out a recess for it, so the plate surface is flush to the body. So that route, as it's more visible than the neck mounting, is even more important to me to get looking good. I might even consider countersinking for a flush-mount trem cover too.
Just to be clear, I'm not looking for "patch-up" solutions. Nothing that "will do OK" or is "pretty good". I'd like to know how to approach this so that it looks "factory", of the same top quality as the rest of the body. I'm not so much concerned with how to do the routing, or gently rounding the sharp edges. My worry is how to get paint on there, and then clear, and then get it perfectly blended into the existing finish with no trace of edge, feathering, or "bumps". I believe Warmoth uses polyurethane clear, which could make invisible blending pretty challenging.
Maybe this has been covered in an existing thread, but if so, I couldn't find it. If you know of such, I'd be grateful just to be pointed in the right direction. Otherwise, I welcome any and all suggestions and details - specifically type of finish, finishing materials, and techniques.
(Tonar, you out there..????)
Thanks!
Thanks!
