Hi i am new here, I just saw a thread here on direct mounting pickups and i would like to share a neat trick i discovered. http://unofficialwarmoth.com/index.php?topic=21361.0
You can use this method by mounting to a fu tone style mounting plate, a humbucker baseplate, threaded inserts into the body or just wood screws.
A few of you might have seen this fu tone mounting plate. As you can see in this video it bolts in and you adjust the height by removing the pickup and adjusting the baseplate. :frowny
http://www.youtube.com/watch?v=cIBEh0jp9kk
Now for my idea.
start with 1 pickup rout like so or threaded inserts etc.
Mount a humbucker base plate. You can buy them from stewmac or if you're like me you will have a few in the spare parts box.
Grind/file away some of the top of the height screws so they can move up and down. ''may need to shorten screws and springs also''
Install with sprigs as normal
The rig,
Here is a simple diagram to explain it using two different methods.
Now for my idea.
The rig,
