How many coats are needed?
jeffjozwiak
OK. So I'm spraying my headstock with clear coat aerosol (stew-mac). How many coats do you think I need to match the body (done by Warmoth) which looks pretty heavy? I didn't use sealer and it took quite a bit before I didn't see grain.
What's the typical or max number of coats you've used?
What's the cure time before polishing? 1 week or 2?
I've heard/read that you need to cure the finish for 1 month before installing the machines on the headstock. Is this true?
joz
It's only the front of the headstock that's being finished. It's Imbuia. It's a Brazilian Walnut but not really a walnut. Just goes by that name.
