ruscio
I'd like to add a coil-split feature via a push-pull tone pot on two Ibanez JS style guitars with DiMarzios in an HH config plus a 3-way toggle. My plan is to use existing volume pot, toggle, jack, and pickups, swapping in a push-pull tone pot for the one in there now and re-wiring as needed. I found this wiring diagram, and I have a few Qs:
1. I never use the tone control, and only want to be able to pull up for coil splitting. Can I simply leave out the capacitor? If so, would the lug normally connected through it to ground still need to be grounded?
2. I can never remember which colors the DiMarzio wires are, can anyone remind me which are N start, N finish, S start, and S finish?
3. Any other tips or advice you'd like to share?
Thanks!
Thanks!
