Hello there!
I'm looking for some help, as i dont have much electronic expertise.. :icon_scratch:
The thing is I have a Maverick Chaos guitar, wich has 2 Humbuckers, a 5-way selecter, 1 volume and 1 tone pot..
I want to install a P-Rails SHPR-1 on the neck position, and a Duncan Distortion (SH-6) on the bridge position..
The P-Rails is a Humbucker that can change its function between four modes: Humbucker in Series, Humbucker in Paralel, P-90, Single Coil..
So for this, I want to install a extra 4-way-rotary-switch to control the P-Rails by itself; and at the same time let the original 5-way selecter do the same job it always did..
I think that this way my guitar will win some extra versatility, while retaining its rock guitar nature...
Basically, i need a good tone for lead (bridge hummbucker), similar in a way to what Steve Vai or Satriani has, so i thought the SH-6 would have enough balls for the job, while at the same time sound warm and organic (i've checked the sound samples and i got this impression out of it anyway..)
The P-rails will let the guitar sound more like a Stratocaster if needed, while at the same time giving me a mellow humbucker tone (i hope!), that hopefully will mix good with the bridge position and be useful for jazz-fussion rock-fussion
So far so good.. but this is easier said than done! :icon_jokercolor:
I have contacted some luthiers in my area (Barcelona-Spain), and most of them tell me that what i want is very hard, or impossible, and that i will have trouble with my actual 5-way selecter, suggesting me to use it only as a 3-way and let the other two positions control the P-Rails..
all wich in my opinion is a bloody mess...
I basically want the guitar to be the same it is now, but i want it to have a separate extra 4-way-rotary-switch to control the P-Rails... this seems the more logical way to me..
Now, i made various pictures of the inner circuit on the guitar, and the guitar itself for if you want to help me out, here they are:
Also here is a representation of the circuit for if you need closer inspection..:
I hope it is clear enough, cause i wouldnt know how to do it better hwhehe :icon_biggrin:
Here you have an example of an official 2xP-rails wiring with 3 way switch and a on/off-mini-toggle
http://www.seymourduncan.com/support/wiring-diagrams/schematics.php?schematic=2_prails_1v_1t_3w_mini
Now lemme ask you all a couple questions:
-Any of you ever tryed any of these two Seymour Duncan pickups?
-whats your opinion on them?
-Do you think they will match well togheter?
-How should i plug the pickups and the 4-way-rotary-switch in order to get the results i was hoping for?
-Do you think i will have to replace the resistance (2A223J), and adapt the circuit for the impedances/resistances of the new pickups?
-Would the circuit have to be modifyed? In wich way?
-Is the original circuit strange, or is it quite regular? Cause i tryed to figure how to do it, looking at diagramas, and i found nothing even close.. all was based on strat/gibson kinda guitars, but none with 2humbs, 5way switch and 1 volume 1 pot...
Well, THANk YOU a lot in advanced, i will wait for your answers and try to reply asap.. and please excuse my bad english, as i'm spanish and all this is quite abstract.. :redflag:
www.ernz.tk
www.ernz.tk
