thesjkexperience
Sorry for the drama, but I am pulling my hair out! The set screws that came with: http://www.warmoth.com/Modified-Mustang-Bridge-Chrome-P616C820.aspx are all too long and I have searched and searched and I can't find the correct size set screw. All the screws are over 1/16" too tall and it makes it harder to mute the strings without cutting up your hand.
The bridge itself is fantastic and even with the screw problem I prefer it to a stock JM and the Mastery I had for a year. It has 2 to 3 times the sustain of the stock JM bridge, but it doesn't leave Jazzmaster-land tonally the way the Mastery does. Plus the string spacing is much better on the linked bridge!
It seems the set screws I need are 2.6M, .45 thread and about 6 mm tall. I suspect it is common in Japan, but I can't seem to find anyone who will sell less than a pallet full. The screws are Stainless so sanding is out. I thought I could get away with no screws at all, but the two E string saddles need to be raised to hit 9.5" radius. If all else fails I will have to look into a small vice and a very sharp and fine hack saw.
Any help is appreciated!
