Hardware Needed?
So I am trying to build a guitar for the first time, but I have literally zero idea for the electronics parts that I will need. I will be using the VIP body from Warmouth, but I do not know what electronics I need. Can someone help and tell me what I will need? Thanks a bunch!
Welcome to the forum.
You need to provide a bit more information.
What type and how many pickups do you plan to use?
Active or passive?
How many volumes and tone controls
What type of selector switch / toggle or blade for example.
What would you like the electronics to do, simple pickup selection or also coil splits etc?
There is some subjectivity in the details but this is what I'd suggest.
2 - 500k Audio Taper Pots (Volume)
1 - 500k Linear Taper Pot (Tone)
1 - .022u Capacitor
1 - 1/4" Mono Input Jack
1 - 3 way Short Toggle Switch
22 gauge stranded wire
Solder
https://guitarelectronics.com/2-humbuckers-3-way-toggle-switch-2-volumes-1-tone/
That should cover it.
Other than what Vince has already mentioned it might be an idea to get long shaft pots for a rear rout body such as VIP.
