Neo Fender
I’ve never seen this done and I’m sure I’m not the first to think of it but some time ago, I came up with the stellar idea of using a pair of hanger bolts and nuts (or better yet, elastic or nylon stop nuts) to hold a trem claw in place:
It could be a solution for a problem that doesn’t really exist, since for most situations, you set the trem and forget it but at least this would eliminate wear or stripping out the holes in the body.
Then, I wondered if you pull UP on the trem enough, would this decrease the spring tension enough to allow the claw to wobble around on the screws and cause tuning issues (again, maybe another imagined problem). So then, I thought about using a pair of nuts on the back side of the claw, along with a pair on the usual (front) side and use all four nuts to lock the claw in place.
However in spite of all this mental exercise, Schaller offers the most elegant solution:
But I’ve read where at least one person installed a Sure Claw and one of the mounting screws protruded into the guitar’s pickup cavity.
Anyway, just thinking aloud.
