I noticed you indicate you are using an American Fender strat hardtail bridge. I am also building a tele deluxe, been months do a lacquer job on it, and when I did a test assembly I noticed the string spacing seems to be off a bit. It is close but no matter how I adjust it there seem to be two strings, at either end, that ultimately are about 1/8 of an ich ormore off of the pickup pole. Your bridge sadles look different from the ones on the SFMH1B Warmoth recommended. Did you use a different bridge or replace the saddles? Or did you get the bridge elsewhere, and if so, what exactly is it?
