Yeah, the neck is mounted to a solid aluminum block. There is a welded rectangular framework of 1/4" by 3/4" aluminum bars that are welded to the block, and extend under the bridge and to a cross piece that the ferrules go through. The top and back are sort of free-floating - the only thing that holds the back against the framework is the pull of the strings on the ferrules, and the top is only held down by the bridge. However, the pickguard is held onto the top with tapped machine screws,so that "solidifies" it quite a bit. There's two big holes under the pickguard, you could easily build it with two humbuckers or put in a middle "Nashville"-style pickup.
Like the aluminum Strats, it only takes the modern "American Standard" bridge hardware, but you can get those with HB holes, and if you want to go nuts I think Callaham and Glendale (maybe Barden too?) are making bridgeplates for that screw pattern. But there's so much metal and it's already such a radical departure from anything like a "real Tele" that buying parts which promise to be "even more vintagey than vintage" for that authentic sound seems bizarre to me. :icon_scratch: With some attention to pre-gain EQ, I can make it imitate a wood guitar somewhat, but that's really bizarre - I WANT it to sound different, I mean what's the point here?
The treble is easy enough to deal with, because it's got a lot of bass & mids too - the instantaneous attack is what's so different. Your basic soft, squishy wood bodies act as a compressor & muffle the notes, and that's what we grew up hearing. This thing BITES. Not the bad bite, the good bite.... Again, there are ways to muffle it, but that would be dumb? So far I've actually found it best for two really schizophrenic styles - fingerpicking jazz with a dead-clean tone, just a bit of reverb - and howling, super-overdriven tones with a couple of sequential boost stages which are softening the initial attack. It really loves a Digitech "Hot Head" distortion pedal that I recently won*, which is in the Rat/Big Muff tonal territory. I just put on a different pickguard with a soundhole, I suspect I'll be able to get some delightful controlled feedback... if we ever get sunlight again in my lifetime, I'll try to get some pictures.
*(Enter contests, or you won't win. ) :blob7:
