ArifSondani
I need help here
does anyone what is the perfect couple for seymour duncan sh-13?
that has a great clean tone
Yep I have that Dimebucker & a 59' is perfect for the neck posy.ArifSondani said:I need help here
Tipperman said:Single coil strat pickups that go bzzzzzzz for clean, IMO. I'm a bit of a black sheep here when it comes to pickups though. If it has to be that humbucking stuff (Why would anyone want that?) a PAF from Lindy Fralin. A Pearly Gates. A Jazz one.
Cagey said:Tipperman said:Single coil strat pickups that go bzzzzzzz for clean, IMO. I'm a bit of a black sheep here when it comes to pickups though. If it has to be that humbucking stuff (Why would anyone want that?) a PAF from Lindy Fralin. A Pearly Gates. A Jazz one.
Humbucking doesn't necessarily mean bad tone. It just means it doesn't hum, which is a Good Thing.
If you really like what a single coil sounds like, you owe it to yourself to unclench $32 and buy a GFS True Coil. I'm not kidding - those things are magical. I've got a pile of Seymour Duncan, DiMarzio, Fender and other pickups either installed or laying around wondering what their lot in life is going to be and none of them even come close to these things. Not that any of those are bad pickups, but they're never what you expect. The True Coil is. Seriously. Nice parts.
Cagey said:Yeah, those Neovins are nice, too. I have a set in my white Strat, and have been very pleased with them. These True Coils are even better, though. If you didn't know any better, you'd swear you had a set of old single coils installed that have just magically had the noise removed.
Basically, they put a small coil on the bottom that's just enough to pull off the CMNR trick. So, it looks sorta like a stacked coil setup, just out of proportion. The net result is only the top coil really produces any signal, so it has an authentic single coil sound with all the frequency response and character that comes with that.
Highly recommended.
Cagey said:I remember reading some time back about a system John Suhr would install that used regular single coils, but tied in a very large bucking coil on the back of the guitar to pull off the CMNR (CMNR=Common Mode Noise Rejection) trick. Same idea, different execution. Problem with that system was it wasn't balanced per pickup, so its effectiveness varied. Also, it was pretty expensive.
TonyFlyingSquirrel said:Cagey said:Yeah, those Neovins are nice, too. I have a set in my white Strat, and have been very pleased with them. These True Coils are even better, though. If you didn't know any better, you'd swear you had a set of old single coils installed that have just magically had the noise removed.
Highly recommended.
This is where they've really taken the stacked pickup idea to it's fullest potential. I remember having some HS-2's & HS-3's back in the later 80's/early 90's, but they just didn't have enough output. In some ways, they had even less output than regular single coils. The GFS's sound true, and keep up with other higher output pickups to boot.
ArifSondani said:so should I buy a '59 or a jazz?
