ACWraith
Google has failed me. Does anyone know of a ganged on-off-on and on-on-on switch? In other words, I'm looking for two differing internal switches with a single physical handle as the interface.
I'm trying to find my ideal control route for multiple pickup configurations so I'm not as focused on front-routing and pickguards for controls. I like the concept of using an on-off-on switch as an inner/both/outer coil selector and a 5 or 6-way switch for the bridge/parallel/series/neck (with some out of phase options thrown in) pickup connection. A single 2-pole switch works fine with dual humbuckers. However, an HSS setup requires one pole be swapped out for a separate on-on-on switch to handle the parallel connection of the single coils in order to keep the neck & middle quack that makes those singles worthwhile.
The workaround is of course to just drill for two different switches. However, I don't plan to ever use them in different positions so it seems like it adds annoying fiddly bits to manage when played. I'd prefer a single ganged switch if anyone knows of one.
