rockskate4x
Hello, everybody. It's been a long while since I have posted any questions of my own here, because I haven't been modding or building for a long time. I have a double humbucker guitar that I have modded with individual coil taps for each pickup as follows:
Pickup toggle
Volume pot/neck tap push pull
Tone pot/bridge tap push pull.
The individual coil taps have been very nice because I have enjoyed being able to have only the neck pickup tapped in order to quickly change my dynamics when hitting the pickup toggle (think tapped neck for verses/ full bridge for choruses etc...). If I did not like being able to do this, I would have used a master coil tap switch because having two push pulls has always seemed like a clumsy way to have that sort of tonal flexibility. My new idea is to use some sort of three way mini switch, but I'm no wiring guru so I do not even know if this is possible. The three way mini switch should have these settings, preferably in this order:
1. No coils sent to ground before before hitting the pickup selector switch (les paul/sg mode)
2. Inner neck pickup coil sent to ground before hitting the pickup selector switch (fat strat w/ no middle pickup or squier 51 mode)
3. Inner bridge and neck pickup coils sent to ground before hitting the pickup selector switch (tele mode)
Is this possible? If so how can it be done?
-skate
			Pickup toggle
-skate
