FS: Scratch-built Tube Head + 112 Ext Cab
fdesalvo
$1100 Local Pickup LA/OC area.  Might ship.
This is my latest scratch build. In my 14 years of building, I have to say this is my favorite so far. It's engagement ring time, so I'm selling what I can to fund it.
*35w Fender AB763 (Blackface) Normal Channel blended with Marshall Plexi preamp values --
*Thick and clean tone -- not piercing highs of typical Fender circuit, so if you want the typical scooped 60s tone, this may not be for you.
*Great pedal platform
*Variable Negative Feedback control on rear to alter feel/breakup and bright switch on front panel
*Bullet proof componentry and over sized Hammond power/output trannies
*2 x 12AX7, 2 x 6l6/5881 -- currently has NOS JAN Philips 6L6WGBs -- will throw in matched spares, 1 x 5U4GB
*Circuit breaker in lieu of fuse with push button reset
*Full turret board/flying lead construction using best possible components, no expense spared
*Bias test points -- very easy to swap tubes and adjust bias on the fly
*Mather built head cab, Avatar 1x12 extension cab loaded with the beautiful WGS ET65
*Very light and portable -- comes with cab slip cover and power cord
*ebay ID: fdesalvo 100% feedback
Build Journal: http://s443.photobucket.com/user/frank_desalvo/library/Scratch%20built%
This pic has a diff set of knobs..
