Tacovan
It's time to document my first (partial) Warmoth build. This project is gonna get weird. It's a 1975 Telecaster bass body that someone abused with a router at some point.
I ordered a lined fretless J neck from Warmoth... rosewood on maple. As for pickups, I have the original neck PU:
And I ordered Jazz PU's from Fender:
Here's a closer shot of the J routes:
Looks like the previous guy put a pickup ring on the bridge PU... to hide the bad woodwork? Who knows. Anyway, another problem I might come across will be mounting the neck.
That microtilt screwhole is blocked by some kind of wood filler that I'll have to drill out. Hopefully the screw turns out because it will definitely affect the neck tilt the way it is now.
I ordered a pickguard from Chandler that should be here any day now, so tonight I'm going to start to prep the body for wiring. I'll be using the conductive shielding paint from StewMac...
One of these two items will be consumed tonight.
The spongy poly brush was used for the larger areas and the smaller art brushes were perfect for the tight spots. The paint goes on pretty easy and cleanup was a cinch.
Here's the first coat...I'll be doing 2 more coats with a day in between for drying.
Love these strings.
Here's another shot of the back. You can see where he drilled holes to convert the neck plate to a standard 4-bolt and filled in the microtilt access hole. One other thing- these Tele basses were a seriously heavy slab of wood! I can't wait to get this one up and running again... stay tuned for updates and thanks for reading.
Love these strings.
