I agree with AGWAN's comment: Fossilized means it has turns to stone, this neck obviously hasn't!
That alone gets me being defensive on the BS meter straight away, why not just announce it as kiln dried/roasted maple? (which they do later in the text)
Wyliee said:
=CB= said:
From the Roasted Maple neck page.....
* Adds dimensional stability and resistance to temperature and humidity changes
* Increases resistance to warping
* Reduces density while maintaining stiffness for a lighter neck with sufficient strength
* Yields a microstructure similar to naturally aged woods with lower moisture content
* More resonance and less damping
* Eliminates the need for hazardous chemical treatments
* Vibrational testing indicates that roasted maple exhibits clearer tone with a stronger fundamental than untreated maple samples
Believe it or not, a certain amount of the science is legit. My best friend is a research scientist for Weyerhauser and was involved in some of the early research. It does work, but can become very brittle and difficult to work with. So.... lets's see. It's the cool new thing on the block, but is is really better than a well built neck made of traditional woods? Probably not, but it sure makes for great marketing!
I'd give the idea about ten years of good hard road work before wanting to go for it. If what Wyliee suggest is a possibility of it becoming brittle that may only show up after a period of time of use (abuse?). Graphite necks were once the great new idea, so too aluminium necks, but they both were found wanting in the real world. And expensive. We are still, in the vast majority, using organic materials for the neck woods....
